DBaker
I have a 8 hp tecumseh engine and want to silence the exaust. Anyone has any idea of exhaust pipe design that could do that?
Thanks!
Thanks!
They would both work. i think "B" would be a bit quieter. If you take "A" and put a stop in the middle of the pipe (literally, a solid piece of metal that nothing can flow through), then you basically have my muffler. The gasses enter the inlet pipe and travel to that stop. The stop forces the gasses to go thru the holes into the chamber. The gasses fill the chamber, and in order to exit, must pass thru the holes out the other side.
If you also use some fibreglass wadding (roofing insulation) between the two pipes it should muffle it a bit moreOn a side note.. Can anyone tell me why is it that an engine with a single 420cc cylinder makes at least 5x more noise than a 3,500cc car engine divided in to usually around 4-6 cylinders?
