side project: mini 3 wheeler
BombBoy94
Somewhere, Virginia
so i know this has nothing to do with karts, but i found one of those mini motorcycles in the garbage a couple weeks ago. got it running, fixed it up and mad it look nice. well i just happened to have two offroad 4wheeler tires the same size as the mini bikes, and i want to put them on the bike itself. i need some help. im thinking fabricating a solid axle that fits in on the fork, transfer the sprocket, either weld it or make a mount for it on the axle. but the issue is the acceleration of the bike, it sucks. any way i can change it without changing the entire motor? its a 49cc air cooled 2 stroke. any other ideas on the setup would be grateful. pictures will be up soon.
DS13
Annoying the Neighbors!!!
Elysburg, PA
That solid axle may work and if ya do that make a sprocket mount DO NOT weld the sprocket or the mount on. To change the acceleration you have to change the gear ratio...
BombBoy94
Somewhere, Virginia
awesome, thanks. and how would i change the gear ratio? a kit or manual orr...?
DS13
Elysburg, PA
any ideas on how to put the sprocket on then? and how would i change the gear ratio? a kit or manual orr...?
Your axle would have to have a keyway in it which has a key in it and the sprocket mount has a keyway in it too. then the mount should have screws where you can take off your sprocket on and screw on another.
BombBoy94
Somewhere, Virginia
Your axle would have to have a keyway in it which has a key in it and the sprocket mount has a keyway in it too. then the mount should have screws where you can your sprocket on and screw on another.
my apologies, misread your post. thanks, appreciate it.
By using a larger axle sprocket or, if ground clearance is an issue, you may have to resort to a jackshaft. Be aware that this will lower your top speed (good acceleration or good top speed, pick one).
At the end of the day, a 49cc engine doesn't produce a lot of horsepower so, getting decent acceleration will always be an issue
BombBoy94
Somewhere, Virginia
replacing the sprocket was the conclusion i came to as well. and jackshaft would be a good plan B, thanks. and im not really needing speed for this, just acceleration. another question, steel or aluminum axle, it needs to be durable, offroad worthy yah know. haha.:wai:
DS13
Elysburg, PA
thats my issue as well. very heavy. im looking through a couple junkyards to find a suitable lawnmower axle, if i can. if not, fabricate one. and ill have pictures up tomorrow. to dark for pics now.
Steel isn't that expensive, well at least where I live, I got a 3 and 1/2 foot piece of 1" cold rolled round for like $9.
EDIT: i mean you could find stronger alum because they do make different kinds but you are gonna pay a very pretty penny for it.
Fallenleopard
N.S.W Australia
If you can get your hands on a complete ATV rear axle of comparable size, you're almost there
I had an idea similar to your 3 wheeler that is close to what fabroman is talking about. I was going to find a motor frame and attach a quad axle I already have to the rear. I was going to make a modified swing arm to fit the axle so maybe you could do a similar thing?
Find a axle then just modify the swing arm to suit
Just an idea.
BombBoy94
Somewhere, Virginia
Side Project: Mini 3-Wheeler (pics)
like i said before, thinken solid axle from a lawnmower, or fabricating one. weve also got an old kart motor, i think 100cc, gonna put that on here.
