Shudders on takeoff
johnjohn
I have a centrfucal clutch by with chain to jackshaft and chain to sproket on rear wheel; when I give it gas it shudders then smothes out ....... Help please
guitarman AL
Hey, been having the same trouble with a torque converter. Mine only does it from a dead stop. Accelerates fine from mid range. Also seems to happen after it has run awhile. Heat related?
sexyvicta
you reckon this applies to weedeaters also?
have been trying to solve a mystery shudder in one of mine for a while now. Only does it sometimes
johnjohn
I seem to have stopped my shuddering by removing clutch ( Hilliard extreem duty ) and with a dremal tool file a cross hatch pattern onto the clutch shooes............
guitarman AL
clutch shuuders
Not sure what you are calling the clutch "shoes." Do you mean the clutch hubs? I seemed to have solved my kart's shudder from Jeremy's advice. My clutch was fairly clean, but the bronze bushing was stuck to the shaft and not spinning freely. A liitle lube undeneath and it is working fine now. Makes sense why the belt was grabbing.
