The title has my question, but im also wondering what option would be the cheapest and such. im looking at this kit right now but I also see you can buy everything separately, would that be a dumb move? this is my first build.
Have you owned a kart before this? If not, thinking maybe another option would be to pick up an inexpensive kart in decent shape to learn about them and get ideas about them. There are single seater karts, two seater karts, the buggy style karts, some with roll cages, some without, centrifugal clutch drives, torque converter drives. This way once you get some experience you can custom build whatever you like with what you've learned. If you're seasoned then good luck with what you decide.
If you are building from the ground up and you have no parts whatsoever.....then the kit might be an option for you. I would check the price of all the parts separately though and see if they aren't maybe ripping you off on the kit
Firstly though, what are you thinking of building? Are you using it on or offroad?
I’m with landuse, tell us your goals for this engine and we can probably help get you pointed in the right direction.
The kit is for the Free Kartfab 2 seater go kart build. https://www.youtube.com/playlist?list=PLzJ0LQjPgipfr9mDUN1PEpkcigEcKjuxK
Depending on how much money you have on hand, you might be better off buying it piece by piece vs one large bulk purchase, just to help. You may not save money (may actually spend more).
I'm most likely going to use it on road.
---------- Post added at 09:46 AM ---------- Previous post was at 09:45 AM ----------
I'm thinking of using a 6.5 HP (212cc) OHV Horizontal Shaft Gas Engine EPA from harborfreight.
---------- Post added at 09:48 AM ---------- Previous post was at 09:46 AM ----------
So I might actually spend more money buying it separately or more money buying a kit?
---------- Post added at 09:50 AM ---------- Previous post was at 09:48 AM ----------
I don't really want to use my budget on a ready go kart, I want to be able to build it. ive never owned a go kart but have driven one of course. I really want to custom build mine and it would be a single seater.
It's a tough call. You would have to itemize each individual part on that list separately and then compare the cost to the whole kit. You may save a few dollars overall, but you'll have to check each item to know for sure.
This is the live axle kit they sell, 38" wide axle. https://www.gopowersports.com/live-axle-kit-complete-38-axle/
You have the options for some upgrades on it.
Axle bearing kit https://www.gopowersports.com/3-hole-axle-bearing-kit/
Axle https://www.gopowersports.com/axle-38-1-diameter/
Sprocket https://www.gopowersports.com/live-axle-sprocket-60t/
Wheel hub x2 https://www.gopowersports.com/live-axle-hub-4x4-pair/
Brakes https://www.gopowersports.com/go-kart-mechanical-brake-disc-kit-9511-9598-th1000/
Shaft keyed ollars need them 1" bore https://www.mcmaster.com/shaft-coll...t-collars/clamping-two-piece-shaft-collars-9/
Key stock, cut to length https://www.amazon.com/GRAINGER-APPROVED-Key-Stock-Over/dp/B01LYJ2K9R
I believe that is everything.
You can live with all the parts in that kit
Add on the two extra wheels. I was at work when I made the list so I had no time to look over it.
Are you talking about the kit for $497? because I dont see the itemized things on the live axle kit.https://www.gopowersports.com/145x70-6-floater-wheel-assembly-complete-with-5-8-sealed-bearings/ here's the front wheel.
I didn't realise until now, when you click on the kit from GoPowerSports and scroll down, they have the whole thing already itemized.
