I would make it about 12 inches wider because it only looks about 2.5-3 feet wide and will be very tippy past 20-25 mph. secondly reverser the front steering, you want the tie rods to be behind so the frame will protect them if you run into something (you will). Also i would move the rear axle up to within 6 inches of the seat to shorten the turning radius as much as possible because a wide turning radius is a complete nightmare on go karts. Next consider where the roll cage is, it's right where you put your head. It really should be around 3 inches above your head when you sit in it, and since your 14 i would add quite a bit of space for you to grow. Speaking from experience, it's very annoying to find out that you grew 5 inches in the 6 months it took you to build the kart and that it's now too small to be comfortable. Since you have no suspension i would suggest using larger wheels than what you have in the drawing, just take a look at any of bighead's honda oddy's 18 inch or so balloon tires in the back to act as suspension. You should also think about a real seat and not a home made one (not sure if the one in the model is just a place holder or not) the home made one will work fine but it might hurt your back while riding it. If you want to save some money the pillow block bearings on the steering shaft are over kill and can be replaced with bushings if you wish since it will not have to withstand any rapid rotational motion. And just as a word of caution i would not go with any thing above 10 hp unless you added some bracing like i put in the picture. The red line is a brace that almost needs to be put in and the blue line is a brace that i would suggest putting in but not necessary.
Sorry about the wall of text but it's just some stuff that will probably save you a lot of searching.(i hope)
