Sharing what I've learned.
Logan County Ohio
Have finished the first season of an outlaw yard kart league.
5th overall in points.
Rookie of year, I don't drive.
Very first small engine build.
First experience with karts. (Long time late model and modified chassis guy)
Set fast time at very first race, got the right rear ran over and sudden stopped the engine, sucked after that. The engine would not rev, played with timing, valve adjustment, carburation and torque converter and gearing. In last race was finally able to run with the pack again, but we had a 10/53 gear compared with the competition's
10/80! Pulled like a bear on the bottom, no revs.
Some background:
We must run GX200 based engines.
Open rules except for NO METHANOL.
Must be naturally aspirated.
Must be carbureted.
212 predators OK.
Must run 30 series converter and 18" rear tires.
My engine started out life as a box stock special. Increased compression to 11:1 with stock piston and rod. BSP-3 cam and stock rockers. Using 0.650" clone carb. Converter engagement at 3300 RPM and set for quick upshift. Best RPM obtained about 5600 on more open tracks and 5200 on the tight ones. I would have expected 6200-6500 RPM with this setup.
What I found was the cam was advanced, probably from the sudden stoppage in the first race. The crank gears are not keyed and may slip if enough force is applied. The cam was almost straight up when it should have been retarded say, 3.5 degrees. Had I more experience it would not have taken all year to discover.
I have corrected the cam timing and made some more changes in porting, valve sizes, rocker arms and carburation. Sounds mean.
I will now engage at 4500 RPM and make use of the RPM range.
One other thing I will share, DO NOT LUG THESE ENGINES WITH THE STOCK RODS, THEY WILL BEAT THE DICKENS OUT OF THE CRANK JOURNAL. THE STOCK RODS SHOULD TAKE AT LEAST 6500 RPM OR MORE IF THE CLEARANCE IS SET LOOSE. (0.003" TO 0.004"), DO NOT SET TIGHT. Oil was 0W30 Mobile 1.
I ran 2 races on the first rod, removed, replaced and clearance it more. Ran 4 more races, noted still, some gald, cleaned and honed for more clearance. A nice crosshatch with a 320 grit dingleberry hone seems about right for stock rods. Billet rods can be revved more but don't abuse them like I did these. (don't hone the bearings either).
Thought somebody could learn from my shortcomings.
Looking forward to next season.
LOUIE
Poboy kartman
Senior Moments Member
White Settlement Texas
Yeah....an old racer's trick was to to take old wore out engines and leave the bottom end as is....(you just can't get the combination of extra clearance and finely mated bearings any other way, really) ....and rebuild the top end for compression.
Sometimes folks are surprised at how large the clearances are for racing engines.
