Shaft Size?
Stephen115
I've acquired a 3HP rota tiller motor. It was belt driven and I'd like to make it chain driven but the shaft seems way too small for a clutch like on my honda clone. any clue on the shaft size and if I can get a clutch for it?
thank you
SJ
souperman000
Westlake Village, CA
first, pull the pully off, then measure the shaft...
if you have trouble getting the pully off: Lots of wd-40 sprayed multiple times a day for a few days (try to soak), use a gear puller, if it still not budging, try a little heat
Stephen115
Do they make shafts that are that small?
souperman000
I dont know what you mean by That small? We have no I dea what you are talking about...pics might help?
why dont you just measure it? it might be a 5/8ths. thats whats on my 3.5 hp B&S
klicky96
Sandusky, Ohio
I once had a 1/2" shaft that had been machined down. Lets just say it wasn't good for kart use. After about 5 hours of riding one day, I rammed the gas, and twisted the shaft. If you have a shaft smaller than a 5/8", I do not recommend that you use it.
dmaznic
dmaznic
Toronto
You can definitly get a 5/8in clutch. If the engine survived as a tiller, the shaft will be able to hold in a go-kart.
The 1/2 in shaft could be okay too. I would question the machining process and machined down from what if it "twisted". Reducing size from 1in to 0.5in is a bad idea.
