drakescale
- Messages
- 6
- Reaction score
- 0
I recently decided to refurbish an old go-kart my grandparents bought me when I was 4 or 5. It's an old Thunder Kart 2 seater with a 5 horse B&S. It's all rusted and in need of some love. No shocks, just a simple flat kart with a bolt on roll bar in he back. I wanted something with a suspension system and a bit more power. In the processing of pricing out new tubing and all that I wanted on it I decided it would be more cost-effective to buy a frame off of craigslist. For $175 I picked up a Murray GT60401x92A.
The Pros:
Has suspension
Working engine, Tecumseh 6.5
All welds, while they look like bubble gum, are in tact
The Cons:
Front wheel bearing appeared to be shot
Engine was missing cover and pull cord
Seat belt doesnt rewind
I've removed the Tecumseh and am in the processing of stripping down the frame to be repainted. I have an 11hp B&S Industrial 25 series I plan to put back on it. Removed the front wheels and checked the bearings. They weren't shot, they were just the wrong bearing. It appears they installed a 20mm inside diameter bearing instead of the proper 5/8" bearing. So the wheels were just bouncing around on the shaft due to the extra space. I measured the shaft with a set of calipers to be sure. The proper bearings have been ordered. Here are my questions:
1. What simple modifications can I do to the B&S 11hp 400CC Industrial to eek a little more power out of it?
2. Currently, it has a centrifugal clutch 10T to 26T JS, 10T JS to 36T drive gear. 16" tires on the rear. Solid rear axle. I suspect the clutch won't hold out so well to the extra power and adult weight on the kart. It will be driven at varying speeds, up and down light hills, bumpy or mushy terrain, and most likely the kids will run it stop and go a lot. My options are a high performance centrifugal clutch or a torque converter. Im leaning toward a torque converter. Which do you recommend?
2.1. Is this the proper gear ratio that I should be running?
Any other suggetions are appreciated.
The Pros:
Has suspension
The Cons:
A torque converter will be best but, let me warn you, a decent TC will set you back around $300 due to the aforementioned 1" shaft
