Semi or full "rear suspension"
leflane4pasnonly
Hello everyone!
Just became a member and I am looking to turn both my 6hp manco dingos into suspension carts and add Honda gx390 motors. My question is...what is better, independent rear suspension or semi independent rear suspension? Just thought it would be easier to leave the frame whole and add a arms to the rear rather than cutting the frame in half and somehow mounting the motor the the back of the seat so the rear wheels could shake all over the place without shaking the motor? Please let me know what you experts think, thanks, Leflane4pasnonly
"Semi-independent"? No such thing. However, I think you're getting at what we commonly call a "swingarm" rear suspension.
It's all a matter of time, ability, and money. If you have enough of them, an IRS is truly the best bet. The easiest and cheapest solution is a swingarm, wherein the engine is unsprung- which is to say that the engine travels with the suspension. Better than that is a swingarm, wherein the engine is sprung weight. In this case, the engine's mounts are firmly affixed to the frame. The rear swingarm arcs up and down while the engine remains in a fixed orientation. This requires the engine's output sprocket to be in a direct line with the suspension pivot to keep the chain tension constant, or a good spring loaded chain tensioner arrangement.
An independent suspension is defined as having the action of one wheel on an axle have no effect on the action of the other wheel. They move independently of each other. This can be done with single arms, dual arms, trailing arms, etc. This will be the most complex and expensive, but will outperform the others, hands down.
