allright i have some pics to help
The first pic is the wire you want to use, its the yellow one coming from the square box. This wire from the factory runs down to the oil sensor probe that is screwed into the block below it, it has a male/female quick connect rite between the oil box and oil probe on the yellow wire, if this wire coming out of the box touches a ground it will kill the engine.
pic 2 is a close shot showing the box and wire.
pic 3 is the wire not to use, just let it hang or tape it up once the wires are seperated at the male/female connector, this is the wire coming from the oil sensor probe that screws into the block.
pic 4 is the horn button, behind the button is a place for 2 wires, one runs from the button to a ground, the other runs to the yellow wire coming out of the square oil sensor box.
simple and reliable, both my karts are done like this. And the low oil sensor will not and can not shut the engine down due to low oil or ruff terrain because the oil sencing probe is not hooked up. you can simply tap the button and shut the engine down now.
