Searching for Power Products Engine Info.
Oldcartrider
I have a Power Products Engine, Bore is 1.625 Stroke is 1 7/16 and I believe it is a Model BV60. The Engine has a domed piston with one side tapered and the other has a notch cut out at 90 degrees. Which side of the piston goes toward the intake port and which side to the exhaust. I found the numbers H2013 and 50377 on the housing, these are the only numbers on it. Has anyone had one of these apart and what is the design reasoning behind the piston.
Staff Murderator
Where’s Sparkwizard? He‘d be all over this,
Post pics good sir.
Staff Murderator
It sounds like you have the motor apart which alludes to the reason you are asking about piston orientation. Pistons and combustion chambers have unique designs usually intended for various combustion principles. Most of them are, I think, designed to move the air-fuel charge towards the spark plug or for chamber evacuation and flow, etc.
Would love to see the piston if indeed it is apart already.
:useless:
Oldcartrider
Search is over, I found a parts book that indicates the tapered side of the piston goes toward the exhaust port. Thanks for the helpful thoughts, there is so little info out there on these engines.
Oldcartrider
