Oldcartrider
- Messages
- 3
- Reaction score
- 2
I have a Power Products Engine, Bore is 1.625 Stroke is 1 7/16 and I believe it is a Model BV60. The Engine has a domed piston with one side tapered and the other has a notch cut out at 90 degrees. Which side of the piston goes toward the intake port and which side to the exhaust. I found the numbers H2013 and 50377 on the housing, these are the only numbers on it. Has anyone had one of these apart and what is the design reasoning behind the piston.
