mbmopar
hi all ,
firstly i'm going to be asking some questions that I kind of know the answers to but need clarification.
saying that, I'm almost done a home built go kart for my two kids 6 & 8 3/4. They are keen to get some driving in on it this fall before it gets really cold and or snows which could be a week from now ( read : Manitoba ).
The frame is mostly free
based consisting of a scrapped snowmobile lift, trampoline frame and weight bench. The front steering is built with ackerman in mind and the "wheel" is an old plane yoke that was used years ago on a family friend's kart. bench seat is mounted on a dakota seat frame so it can adjust about a foot forward for the short lad, and back for the tall girl.
The rear tires are approx. 18" diameter, 60 tooth axle sprocket, 40 chain, 10 tooth clutch sprocket, 6.5 Powerfist engine (clone).
I had it up in the air on the weekend ( jackstands ) and had one less link in the chain, it was too tight. so I removed the chain and resized the length. before reinstalling it I ran the engine and the clutch engaged slightly. like there was a slight drag on the drum. Being and new clutch, lubricated to mfg spec upon installation, i contacted Hilliard, they responded with some good info and suggested I install the drive chain and block the kart on the ground and fire it up. The chain stopped the premature slippage and things were looking up. at this point there was no signs of grabbing and overheating, the drum as quite cool to the touch after the engine had been shut down.
That was last night.
Today on my day off I tried to get the kart done for this coming Thanksgiving weekend so the kids could enjoy it.
I set all the cable tensions and went to drive the cart out of the garage. No go.
I'm a big guy, maybe too big, but it wouldn't move more than a few inches.
I came back in and read some threads and went back out side, rolled it onto the lawn and tried it again. The front lawn has a slight grade to wards the street. The kart moved ok straight down the grade under its own power but as the grade flattened and i turned the steering axle to give it a try the kart slowed right down......and the clutch got hot. Saw some smoke and the paint on the drum looks like my trailer fender when I overloaded it with limestone and the tire rubbed - hot and bubbly, see pic. I will say I think there may have been some oil from the bushing that may have slung under the drum as I saw some drips on the ground under the clutch. I will wait til it cools and see how slick it is inside as well.
I'm going to ask , I have a feeling I need to re-adjust the axle ratio:
A ) should I bother getting a 72 tooth sprocket or
B ) set up a jackshaft.
At this point I will have some finishing work to do, like floor extensions on each side, seat belts etc but and over anxious for the kids to have some fun. They are young and don't need a high speed machine, i would like them to get moving and have the push up some slight grades, etc.
if I am right looking at jack shafts, then the ten tooth engine / clutch to an 24 tooth j/s input, then a 20 tooth j/s output to the 60 tooth axle should give me 7.2:1 ratio.
do I need more ratio for the taller tires? suggestions on the ratio to shoot for if so. I used the Burris racing j/s calc.
Thank you all, I've learned alot so far on this site, and thanks for sharing your thoughts on this build.
Derek
PS - engine pics coming v soon
Derek
