so i drive the kart today, the steering is much improved, i can now make a u-turn in the street, and go over bumps without, well i guess you could say without bump steer, the steering is also slowed down so i don't have to deal with it bouncing all over the place anymore. one thing is that it makes a loud noise when i'm coasting, maybe it makes the same noise all the time, but i can only hear it while coasting, also the kart doesn't seem as fast. so i think think either the chain tensioner is too tight, the first chain is too loose, which either of those would cause extra resistance, and that would cause the tc to not wan't to shift properly, what are your thoughts? maybe its time to lube the clutch? i prob only have like an hr or two on it.
EDIT: i think the sprocket on the tensioner may be rubbing the side of the chain, could this be the problem.
