Could we see a picture of where the throttle attaches to the carb?
ok umm the cables join into one cable from the carb and the engineYou could look here for a longer one
http://scooterparts4less.com/ALL_Cables.htm
Explain a little better what you mean. There is just 1 throttle cable.
Goes from throttle to handlebar.
What do you mean from engine ?
Ok now i understand two cables. Can you post a pic of the engine and the cables, sounds like it has oil injection. If it does then you can eliminate that and use one cabe then premix gas.
I wouldn't,
You can extend the single cable side by welding a new cable to the old Y connector.
Or just find one that is long enough (what length do you need?)
I wouldn't,
