School me on this carb
Iron John
NA
I picked up this carb a few years ago for cheap. It's new.
What is it, is it any good, etc., etc.
I need to retrofit a carb to a 5 hp Briggs flathead kart engine that will be used on a fat-tired minibike. This little baby might do the trick - it is already set up for a cable throttle - tell me more:
JollyKarter
Texas
Am I correct to assume it is a round slide? Does it have a brand name on it anywhere? What about choke/cold start provisions?
Staff Murderator
I see the word "CHAMPION" on it, along with a stylized lightning bolt logo...
Staff Murderator
Gee thanks Captain Obvious.
As long as you dub JollyKarter as Captain Oblivious, I'm fine with that moniker. :D
That chancer fella--always hindering and not helping. What a dead-weight to the forum. I dub thee: Ensign Flotsam.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Its Fellow.
Like "He is a Fellow at the DIY Go Karts school of Advanced Kart Studies"
2SlickNick
American Minibikes @ FB
Mesa, AZ.
It appears to be a carb either out of a 150 or 250cc scooter.
I can see the fuel enrichment valve.
You will need a 12v power source to operate that valve. Or convert it to a manual one( I did this before ).
Iron John
NA
The enrichment is for choke, correct? (There is an electrical connector.) Should work fine on my 5 hp Briggs, then, yes?
---------- Post added at 02:32 PM ---------- Previous post was at 02:31 PM ----------
I assume it is a round slide. I have not opened it up. No brand name I can see beyond 'Champion'.
2SlickNick
Mesa, AZ.
It is similar to a choke...Instead of choking off the air - it starts off with a wide open valve allowing in a rush of fuel. As the engine is running ( with a 12V ) a heating element warms a wax plug and that starts closing the FEV allowing in less fuel for the desired air/fuel ratio.
also I think it might be a knock off of a keinen( forgot spelling) carb
