Rust!!!!!
trenton davis
watseka il
so I'm trying to pull apart an axel and i come to find that every nut and bolt sprocket hub and brake drum are rusted on and will not move an inch no matter how much i pound beat and spray product (such as yield pb blaster wd40 and oil) on and then pound and beat some more nothing will help strip this axel. does anybody know of something that will get in the threads and un rust it so i can take it apart and re use it or is it a lost cause and i should just chop the axel off and buy a new one.
Wow that's tiny print..
Using heat helps alot to free bolts and other parts rusted together.
trenton davis
watseka il
i was going to torch it but i figured the flame with all the products that were on there would make a very large fire or the heat would warp something
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Warped or "just chop the axel off and buy a new one" anyway. Try the torch you have nothing to lose right. may be worth a try.
trenton davis
watseka il
yeah if anything happens to it i can just get a new axel id need to at some point as there is like a digit and i kid you not the people that i bought it from must have lost the nut that held the tire because they drilled a hole through it and put a bolt through it :smiley_omg:so it couldn't move:lolgoku:
Howabout a description/some pics of the vehicle this belongs to.
Buying a new axle, sometimes easier said than done.
trenton davis
watseka il
here is the axel as it sits any further help to get it removed would be greatly appreciated.
crazykart
Crazy member
Swartz Creek, Michigan
Pb and heat. Spray pb between axle and component, give it a min, then give the component some light taps to work it in more. Then apply heat, get it good and hot.
My suggestion at this point would be to then quench it by splashing cold/warm water on it. Which since you would be going from rapid heating to rapid cooling the expansion and contraction of the metal would help to break the rust free.
May need to do it a cpl times, but keep at it and just tap the components off slowly and evenly all the way around.
Hmm I wonder if soaking it in coke overnight would work too...
