Running in circles! Need help finding a brake hub.
Bbenton2000
I have a golf cart project with a kz1000 engine in it I’ve been working on for a while. I’ve put a new 1” live axle on it and ordered a brake kit. The issue I am having is finding a rotor hub for the 1” live axle that fits the rotor I ordered. I’ve been looking far and wide and keep hitting dead ends.
The rotor I ordered has 10 bolt holes, 2 holes directly across from each other have a center to center measurement of 68mm. Any help would be super appreciated. Thanks all!
Howdy & :welcome2:
Please post a link to your hub & rotor
...so, we know what specific parts, you're talking about
...& can potentially advise ;)
Thepartsguy
I don’t think your gonna fond a ten bolt hub. those disks We’re made for live axles that run splined hubs. the best I can do really is ask yo to lay it flat and check the bolt spacing. if two bolt holes directly across from each other space out to 5-1/2 inches and two bolt holes measure up to be just a hair under 2 1/2 inches then a gopower sports hub should work. you wouldn’t be using all ten holes for any hub you get. it’s probably setup that way for multiple hubs with multiple different bolt spaceing.FD8E9C84-67FD-426B-8266-3B8D3AC31534.jpeg3BF52E64-79FC-43FD-BE76-530E5DE8088E.jpeg
