Running engines on homebrew??
bigfootrules31
I have a couple of old cars and motorbikes that i like to tinker around on experimenting with,:auto: i have a 25L still that'l produce about 60-90% alcohol quite cheaply has anyone ever tried running there engines frequently on alcohol or will they even run?
:cheers2:
robbie
Osceola, Missouri
You'll need to make sure that the seals and gaskets in your fuel system will withstand alcohol. There is one group of substances that is compatible with petroleum, and another group that is compatible with alcohol, and another type that is compatible with both.
Also, you need a bigger metering jet for alcohol.
Back in the good old days (before the 1940s) multi-fuel engines were more common. I just read the wikipedia article on the Model T recently, and it was originally equipped with a multi-fuel engine.
anderkart
Surprise Arizona USA
I've been running Methanol in my 4-stroke race kart engine for a couple years. To gain the benefits of using this fuel my engine has extra high compression and more advanced timing. All this ends up producing somewhere around 25% more power than I could with Gasoline, but running this fuel does come with some drawbacks:
Methanol powered engines typically end up consuming about twice as much fuel as equivalent gasoline engines, so your jetting would need to be much richer. This very rich mixture tends to wash down past the rings and ends up polluting/breaking down your engine oil.
Methanol also tends to absorb moisture from the air, this ends up corroding the carb and my fuel pump unless its all flushed out. Methanol also tends to soften plastic and some rubber fuel lines/components.
So after each day of racing I go through the extra hassle of completely draining my fuel tank, and then run the engine on gasoline for a short time to flush all the Methanol out. After that I Immediately change the oil so any moisture or dirt will still be suspended in the oil.
Another drawback is pure Methanol doesn't offer any Top-end lubrication like Gas does, so I mix in an additive sold by VP Fuels. (although some racers buy the more expensive Methanol grade with additives, or just pour in a little 2-stroke premix oil instead)
You could experiment with adding a little of your home brew to gas, but I doubt you'd notice much difference unless you had more compression/timing and the correct jetting to reap the benefits of running pure Alcohol.
bigfootrules31
thanks everyone for the useful info
i'm going to try runing about 60 fuel / 40 alcohol to see if i can get any more power and if the seals in the carby holdup. i think it'l be pretty neat if i can have a motorbike that i can run for a lot cheaper or free :wai:
redsox985
PA
How do you make your alcohol? What's the recipe for the mash? I'm assuming you boil off the alcohol and run the steam through a condenser coil.
Bluethunder3320
yeha youll need different fuel lines with methanol. it expanded my lines about 4 extra feet. LOL.
and methanol fuel lines with regular gas do the same. but it depends what kind they are.
