RPMs upgrade
pearl111
Baltimore, Maryland
Hello again I have taken the governor out of my predator 212cc hemi engine. I plan on upgrading with the muffler air intake and gas jet that I can get at the online web sites. Can any one tell me about how many RPMs I will be able to get after all the work is complete. If the work I do works out ok are there any other cheap and easy to do upgrades that will give the engine more HP and or RPMs. thanks for any info or help. mike. (pearl111 was not suppose to be me but anyway) thanks again for any help.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Ok "Pearl" lol
The stock engine is governed to 3600 RPMs. Removing the governor allows more RPMs at about 5400RPM the stock valve springs cant keep up with the higher RPMs. So the engine does not increase in RPMs beyond 54 55 hundred. So as a driver you can hear and feel this effect. Now that is your new governor.
This effect prevents RPMs from going beyond the strength of the stock Rod.
The other upgrades Exhaust header, inrtake and Jets. Allow the engine to breathe better and increase HP 1 or 2. There fore allowing you to get from idle to 5500 faster.
As far as I am concerned that is all a Go kart really needs to have a blast and tear up the yard and piss off the entire neighborhood~!
Everything else is just bragging rights, unless you got 2 or 3 good buddies to compete with, but still just a pecker measuring contest.
Ok "Pearl" lol
So building a kart for a contest is ok, but building an engine for that kart is a pecker measuring contest.
Sounds like 2nd place talk!??? LOL
They nailed it. If you want more than 5400 RPM, the next stage of upgrades are camshaft, billet connecting rod, and stiffer valve springs. Around $200.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
LOL
Good point!
But I feel a little insulted and will now have to remove GAB from my profile! LOL
FreeRunner15
So mine must be pretty big. and it's only gonna get bigger. perhaps too big now that i have a non hemi header to modify.
---------- Post added at 09:27 PM ---------- Previous post was at 09:14 PM ----------
depends if you want to be like the rest and get a good camshaft for $70 or buy the best and get a $100-$140 cam for a custom one. But it takes some real time studying about camshaft specs to know what suits your needs.
