ginoz28
Is there some sort of magic box to set the rpm at a certain point to not blow the engine with the governor off?
Sent from my HTCONE using Tapatalk
Too many variables to give a number. Usually between 5000-6000RPM, but not written in stone.
Motors dont believe in the saying"... what doesnt kill you... can only make you stronger...".
well ther IS indeed such magix box...
called a programmable CDI;
unfortunately I don't know of any that's made for a GX ..
and although I haven't actually searched for one, I doubt somebody cared to make one that dropfits a GX
Anyways.. a (I think most) programmable CDI can be used to limit the rpms to any given upper limit.
No you didn't understand..
the GX ignition coil is already a CDI (capacitor discharge ignition)
The magic word is "programmable"m
And the gy6 cdi isn't programmable, even the "unlimited" cdi isn't,
at best it's trimmable.
That depends aswell... But if everything is done very correctly... 7-8k... Btw do NOT put a set of 18lbs springs in w/out putting a billit conrod in... Well u 'can' but u may have to rebuild/replace the entire motor, due to a metal rod ejecting through the case.
