Desertduler
- Messages
- 1,736
- Reaction score
- 10
Rodney,in the video that you are referring to as (looks fast) the kart ran pretty good with that set up that I was testing but not the best, I have different cylinders which I have modified for different power delivery and rpm levels and the best one overall that I tested and settled on is the one in this video which does not give the maximum rpm that I can achieve with this engine which is a tad over 9000 rpm it is the one that the engine rpm turns 7500 and change, the 7500 rpm cylinder gives the kart a top end around the mid 50's but the kart is faster overall with better lap times on the lakebed tracks that I set up, the rear tires brake loose of course on the lake bed dirt to a degree when the engine spools up on the pipe but I can control it and I may play around with adding some weight to the flywheel in order to smooth out the powerband a bit and try to achieve more tractable power. So far this is my favorite set up here in this video, not the the fastest on the top end like I say but the best overall with one gear ratio.
https://www.youtube.com/watch?v=FaTL65TtVaI
