vinijackson
Sally's Nightmare
Hi from Vermont. I recently purchased an X machine and a Manco Dingo. Both run and are drivable. Both need some TLC ... one begins breaking up at high speeds and needs 30-40 feet to make a U-turn. The other needs a belt or an adjustment to the clutch. I work as a machinist and am fortunate in that I can make things that I can no longer purchase, for example, when I first purchased the X Machine one of the front spindles had been broken then weld repaired which broke again prior to my purchase. I turned down the spindle end to remove the weld and welded it properly now works great! My stepson loves it!! I hope to find help with these projects and offer help if I can to others.
