rookie cart-er
birdman58
hey guys i'm new to this and would like some help.i've been reading around this forum and there seems to be some knowledgable people here, so listen to this
i have acquired a murray cart frame from a friend i believe it probably came from walmart many years ago, it is white with plastic bucket seat, electric start, and has suspension on front and rear, the frame seems to be sound, 1'' rear axle with sprocket and 40/41 chain that comes up to another sprocket mounted on the frame with an extra sprocket ( had no engine when i got it so i'm guessing the extra sprocket is for the the chain that run to a centrifigual clutch on motor shaft ) i got a 205 cc briggs and stratton (horizontal shaft) pretty much brand new with nothing on it. so i need some help, how many teeth does my clutch sprocket need? how do i rig my throttle cable up the new motor, when the throttle lever is stiff and has no recoil? what size tires do i need to run? do i need a centrifigual clutch?
I wanna go around 20 - 30 mph if possible, help greatly appreciated.
Blazkowiez
Kart Aficionado
Houston, Texas
You need a torque converter, your kart came with one new. If you place a centrifugal clutch on the kart then it will not run, think of it as starting a car in 4th or 5th gear, it will smoke the clutch very quickly, you would not get down the block. You can use a cent clutch if you use a jack shaft assembly which would stick you with one gear ratio instead of the torque Converter which will give you a variable drive which will give you a much better take-off and top end.
On the engine you will need to convert the linkage to snap back and figure out a way to hook it up.
The kart when new had 18x9.50-8 tires rear and 145/70-6 tires front.
Could you throw up some pictures so I know exactly what you have left from the kart when it was stock?
birdman58
Back to the ol' Northern tool catalog i suppose, do i need a torque converter kit? and could you further explain why a torque converter is necessary? do you understand what i mean about the sprocket set up?
will post pics soon
Blazkowiez
Kart Aficionado
Houston, Texas
Yeah, your kart has around a 60t sprocket on a 1" live axle. 1/2" pitch, I fully understand that. You might consider buying an assembly from BMI they have after market series 30 assemblies for around 170? Northern does not stock Comet parts anymore because Comet is bankrupt and does not produce clutches anymore.
Okay, a torque converter is basically an automatic transmission, it varies the distance of the belt riding on the two clutches using centrifugal force. It moves from 19:1-4:1 in a smooth variable motion that will allow you a great driving experience.
birdman58
i couldnt find the kit at BMI , and i'm assuming i need the 40/41 pitch converter?
edit: would a centrifugal clutch work if the chain just ran from the axle sprocket to the shaft?
Blazkowiez
Kart Aficionado
Houston, Texas
No. It will not have the right ratio. Re-read my first reply, the second sentence just told you the same thing.
SKU Number:473441-30
Price: $165.95
Make sure your briggs has a standard 3/4" shaft that is at least 2 and 1/2" long.
birdman58
Thanks alot for the item number, yes my motor has 3/4 shaft. I will order that asap, but have no idea as far as installation goes, i know i know forgive me for being new.
Blazkowiez
Kart Aficionado
Houston, Texas
Its cool man, I'm just trying to help out. Hell, I did just send you an online link to a store which is in competition with mine. Heh.
birdman58
i talked to the original owner of the cart, and he said it didnt come with a torque converter.
Blazkowiez
Kart Aficionado
Houston, Texas
If it has 6" in the front, 8" in the rear, full suspension, independent A-arm front end, and an adjustable seat the kart had a torque converter from stock, I can not remember if it used series 20/30 but I know it had one.
The kart may have only had a jack-shaft when the previous owner had it, but I 100% assure you it did have a TQ. I am not wrong in this. I've seen too many of these stock.
Blazkowiez
Kart Aficionado
Houston, Texas
It would have to be nearly the size of the tire, heh.
Jackshaft is your other ratio, when you add a jackshaft you have the ability to alter your ratio. Think of that as an ability to make the sprocket on the axle act as though it were twice its size, which is basically what you'll end up needing for the kart to operate properly.
Play around with some gear ratio calculators, when you see what speed you need to be, you will be able to determine what size each sprocket needs to be. If you can not figure this out give me a heads up or anyone else willing to help here, we'll be able to tell you what size sprockets you need.
Your clutch will be a 10/34, your final drive sprocket is 60t? The 2 undetermined sprockets will just be the ones on the jackshaft. I think we can take care of that very easily.
I will say though, as I've stated before, the toque converter will really make the kart wake up and perform the way it was intended to perform, you can go without one but not without the jackshaft and you will not be happy with take off or top end.
birdman58
i hate to ask about the competitor man, but does bmi have them in stock since comet is finished??
Blazkowiez
Kart Aficionado
Houston, Texas
Dude, I have no freaking idea. Thats like asking Pepsi if Coke has a new spokesperson, you'll have to pick up the phone and call them.
gcarter95
Ottawa, Ontario
Their listing says "Backplate, Cover and Belt are all original Comet Parts. Driver and Driven are "copies" of the Comet...works just like originals. "
So I guess they are putting together hybrid kits.
