Roketa 200cc engine.. any input
1992suburban
I wanna go FAST!!
Sanford, NC
•Gear Ratio: ◦1st Gear: 2.769 ◦2nd Gear: 1.882 ◦3rd Gear: 1.400 ◦4th Gear: 1.130 ◦5th Gear: 0.960 ◦Primary Reduction Ratio (IP): 3.333 ◦Final Reduction Ration (IF): 2.706
Rickracer
RM250 Race Kart Driver
Kissimmee Fl.
Sounds like it might be worth the risk. With a 12 tooth front sprocket, I think I'd be looking for a 25 to 28 tooth rear sprocket. QRC has em, on up to about 33 or down to 23, got their 23 on my kart now. :cool: I'd also find out what range of sprockets are available for the front, one tooth up front is about the same as 2 or 3 teeth on the rear. Might wanna go up on the front. ;) :cool:
Rickracer
Kissimmee Fl.
That counts the bike rear sprocket, which was probably 39 to 45 teeth, and it had a much taller tire. :cool:
I'm at 13 and 23 and I'm thinking I may need to go higher, like up to a 13 or 14 tooth front sprocket, 23 is as low as I can go in the rear unless I make something, but I can buy up to a 15 tooth front for like $10. I don't think the chain would clear my shift shaft with a 15 tooth front on it unless I redo my tensioner (maybe make it adjustable?), or redo my motor mount to change the angle. My kart seems to launch way better in 2nd gear than it does in 1st. :confused: :cool:
1992suburban
I wanna go FAST!!
Sanford, NC
OK rick so in 4th gear your tellin me that your motor on your cart turning 8000 rpms the sprocket is turning 8000 rpms ???
NO SIR I disagree
1992suburban
I wanna go FAST!!
Sanford, NC
My math tells me I will need a 20 front and 23 rear in 4th gear to go 64mph @ 8500 rpm since it prolly wont pull that much in 5th
1992suburban
I wanna go FAST!!
Sanford, NC
i found an 18tooth. 520 chain with hub!!
with a 15tooth drive sprocket
thats 58mph in 4th gear with 11 inch tire PLENTY FAST
Rickracer
Kissimmee Fl.
Doing some more reading on Gear Commander, it seems that primary is actually the difference in crankshaft and clutch shaft ratios, which I assumed would be 1:1. Looks like I gotta do some more investigating even for my own kart, :confused: No way I'm only doing 70 in fourth though, I was doing 55-60 on the race course with the old Honda motor, and I'm way above that now.
My primary must be different....... :rolleyes3:
Where did you find an 18 tooth rear sprocket and hub? And what's the bolt pattern? I wonder if it would fit my current hub?
