Building on the DIY method is always an adventure in tweaking, and the bar stool is no exception.
My engine was too large for the barstool and torque convertor combo. I'd thought of cutting the back legs off and making some framing supports to hold it, but I was loathe to make the bar stool look less like a bar stool.
Then we found the answer! The ring that supports the legs of the stool is mounted on the outside of the legs. But, if I took the support off, and reattached it on the *inside* of the legs, I'd get an extra inch in all directions! And it still looks very stock, just wider. (See the pic)
After figuring that out, it was time to start making a frame plan. (same pic)
A lot of people email me and ask "where's the plans!? What's the measurement for XYZ?" Well, this is how I do it.
I like to get out some chalk and draw the frame on the ground. then you can line up things and see how they look. For a bar stool, it's a pretty simple plan. I'll post more as it is built. And on this one I'll write down all the measurements as well.
So far the wheelbase will be 28". The outside tire width is about 34".
