ryf
- Messages
- 309
- Reaction score
- 0
ok so this is kind of out there but I am going to put it on here to bounce it around. a open differential from the front of a quad or a light duty inline car etc, put a brake on one side and a output chain/pulley on the other. when you release the brake it would spin the side that requires the least force, the rotor, set the brake (aka clutch) and it would transfer energy to the drivetrain, it would be a softish clutch, but using a rotor and caliper it would be cheap to service and easy to work on. I am still tossing the idea around but I know the theory is sound, just not sure if it would work in practice lol. simple theory now moving to stage two......
stage two of this, which applies to me. I use a 2 axle peerless transmission with open diff on my cart, if I apply the brake to one side and output from the other, I cut my needs for a jackshaft and it will REALLY help with uphill (under load) downshifts (in theory). if I put a centrifugal clutch on the input/engine side (or left my belt clutch in place and figured out a linkage to do both) I could then shift the mower transmission with ZERO load and input torque (allows shift on the fly without trans damage!!)
thoughts or prayers? lol
