riding mower/go kart
nissinator
kansas
can i push start a riding lawnmower...if so how??? would i be able to switch the pulleys and belt with sprockets and chain???
klicky96
Sandusky, Ohio
Okay, on todays lawnmower setups, no. The belt would probably slip first. To answer your second question, you would need to get a 1" Clutch for the engine, then line up the chains perfectly(which is nearly impossible from the bottom of the mower because you cant get a good enough view). You would need to do a lot of measuring and guessing to get exactly where you need your sprockets.
If you are just trying to make the mower go faster, I suggest a power-boost line hooked up the governor and a smaller transaxle pulley. By a power-boost line, I simply mean a string hooked up the governor to where you can pull the string and pull the governor back.
