Riding Lawn Mower Engine
gvfc2
wishing i was living
Tacoma,wa
well since it might be a hydrostat i dont recommend it either. if it was a 5 or 6 speed i would recommend it
Ewallen
Thanks for the advice machinist. But it is indeed a manual gear box w/clutch. I took the pto off to acess the pully comming from the engine. It appears to be pretty small. And the pully right above the axle is pretty big. ????? I thought that's how it's suppost to be set up in order to go fast. Trust me, it's not fast right now.
Ewallen
What would i have to do to make this thing top out around 40
cumminsbayou4x4
fairhope alabama
yeah but it depends on how fast he wants to go id say im ok with going 20mph on a stock lawn mower only thing changed would be the pulleys and a gas peddle
gvfc2
Tacoma,wa
Just because you're willing to, doesn't mean it's a good idea. 20 Mph on stock mower bits is dancing with the Devil.
not to sound like a broken record but if you seal and put gear oil in the tranny it should be fine. just expect to be rolling it
You may sound like a broken record. But I am NOT talking about the tranny. I'm talking about trusting your valuable backside to pivoting axle beams, totally subpar and sloppy sector-shaft steering gears, weenie tie rods with Dollarama-quality rod ends, wheels often held on only with snap rings, brakes that wouldn't stop a thought at those speeds- And that's just the stuff I didn't have to think about for more than a half-second.
CB4x4 can do whatever he wants (and so can you) but I would never advise gearing for 20+ MPH on an otherwise stock tractor. It's stupid.
Ewallen
What DO i need to do about the steering? Any advice for what kind of upgrade to put on it? Keep in mind im going to build this for off roading.
Ewallen
Yea. I guess you could say I'm trying to make it a crappy ATV. So a little bit of speed. Yes, but I need to keep the torque as well.
