Okay i replaced a centifical clutch on a cart i bought and it got hot fast. I assume over loaded due to the cart size. It has a 10 tooth cent clutch with a 54 tooth axle sprocket.
Here is my thought to solve the ratio problem. It has a jack shaft on it since it probably had a torque converter on it before. So if i went from 10 tooth on clutch to say a 15 tooth in on jack shaft then 10 tooth out to the 54 tooth axle. (which should give me a 8.10 gear ratio). Would that be a tall enough ratio to not burn up the clutch? If i went to a 20 tooth in on the jack shaft i would be at like 10.80 ratio which is pretty high.
i am not looking for a lot of speed really. This cart would be used in the yard or flat dirt roads. very little elevation changes.
any opinions would be helpful.
