Revving and dying
jonboy
Owensboro, KY
Ok so its been a while since I've been on here. I am having a bit of an issue with a newly acquired kart. It has a predator/ clone motor on it and it will start and run and idle fine but when I give it throttle it bogs out and dies. I have pulled the carb and cleaned it very well and it has good gas. The main jet had some crud in it but the float and pilot journal were clear and clean. If and when I can get it up to speed it revs high and acts as if it is bouncing off the governor then bogs out and dies. Do I need to check the valve lash? Check timing? Or am I missing something else?
Ebrownie
Western Montana
Does it run fine under no load? Try lifting the tires off the the ground or disconnecting the chain and see if it revs up fine.
