ironbutt
So...I'd like to be able to reverse a Honda clone's PTO direction by rotating the engine 180 degrees. This would have the cylinder with air filter facing forward rather than backwards.
There are several reasons to do this, one being that my gear box is oriented clockwise rather than counter-clockwise.
The other is the appeal of getting direct air flow for the intake and cooling of the cylinder flowing directly from the front of the bike.
I saw a yootoob video of someone fitting a drive shaft to the flywheel side of a Predator 670cc engine for fitting onto a tractor.
Does the flywheel side of the shaft have the necessary support and configuration to meet the torque requirements of having a clutch or sprocket attached on that side?
Has anyone done this before?
Thanks,
Thanks,
