Rev gauge wiring?
r_chez_08
Should be in the shop...
Cornwall, UK
Ok, I acquired a rev gauge. It was in my car but didn't look right, so I have replaced it with a more oem style one.
Want to wire the old gauge to my kart.
There are 4 wires, Red, black, white and green. I've figured red and black are the obvious, white is for the back light and green is the rev input.
Not sure what to connect green to though?
The motor is a Honda clone.
Cheers
Rob
Not likely to work for you. That type (automotive) of tachometer generally won't work with a single-cylinder, magneto-fired engine. This is why folks resort to a cheapo Tinytach, or a waaay-too-expensive kart computer (Digitech, Digitron... Something like that).
jamyers
Buffalo Gap, TX
Yup, older automotive tachs typically trigger off of the distributor make/break signal, newer ones simply read off the Crank Sensor - neither of which will work on a magneto.
Sadly...
anderkart
Surprise Arizona USA
It wouldnt hurt anything to try connecting the green wire to your engines kill switch wire, and see if it'll trigger the tach or not. (If the tack was made for a 4-cylinder engine, dont be surprised if it reads out at only half of your true rpm)
jamyers
Buffalo Gap, TX
I'd be afraid that the magneto voltage would burn out the tach...but if it's a spare part anyways, why not try?
Hmm...wonder what it'd take to reduce the magneto voltage to a tach-usable level...maybe something like these 12V-to-5V voltage reducers, only bigger components?
http://14point7.com/forum/index.php?topic=365.0
