Hi - I'm new to Go Karts and I'm doing a project with my lad on an old Manco Dingo 285 fitted with a B&S engine. The Kart has no control and takes off by itself - the problem is around the throttle / linkage etc - the butterfly on the carb just will not turn back to idle - getting WOT is no problem and the vibration of the engine does that by itself. Ive tried changing the main spring on photo but no effect, i cant easily reach the govener spring but can see it looks ok but difficult to say. Ive tried putting springs on the carb butterfly in various places but minimal tension prevents the throttle opening or just keeps it open. Ive adjusted the tension in the pedal cable. cleaned and greased everything i can. is there any pictures of the same set up to see whats wrong? or suggestions? thanks.
