retarded vid, but so much fun!
KieranM
Doin It!!
Kilkenny, Ireland
Why is this in the projects section?
Good question
Ohh and i only use retarded when referring to a engine which timing has become messed up eg missing, be it by slipping a tooth on the belt or not correct adjustment. Which may lead to valves hitting piston, and bending. Also the french use it for late.
So a retarded vid is a slow vid to put it basic.
Bluethunder3320
yeah, i just felt like posting it. hay, lucky i was at least wearing something on my feet, lol. i have gone down hard and that means i have had the rope jam in the FRONT TIRE sending me over, and that explains my beat up legs. no head injuries yet.
and yah this thing took me 4 months to build because i dont have a welder or any money at all so basically its been a struggle to build it. its so crappy i tore it apart and im rebuilding it.
redsox985
PA
Your brain development is going to be retarded without a helmet next time it fails worse than front wheels falling off. Which is pretty bad in itself.
Bluethunder3320
haha ya at the end the tires came off because the vice grips (in place of a nut) werent tight enough
redsox985
PA
How the heck have you lived to whatever age you are? Dumb luck? I'm sorry but you are laughing off catastrophic failures that could be life endangering.
Bluethunder3320
14.... its not that dangerous... i mean other people have minibikes and go 50mph my little homemade goes about 20 with towing power. the power wheels tires are plastic so if they fall off it doesnt even matter you just slide
Bluethunder3320
yepp. after falling on the steering cage (underneath chassis) about 100 times it doesnt work that well anymore so i put it aside for now and when i get a welder i will weld scrap metal to stress points
