Replacement Bearings for Jackshaft
EpsilonZero
...still cheaper than a boat!
My son's Razor Dune Buggy blew out a bearing in the jackshaft and I am trying to find a replacement. It looks like a single row deep groove bearing measuring 13mm bore, 27mm outer diameter, 7mm width. So far, I haven't found one. Does anyone know who might be a good supplier for the part? I've been looking for a while now with no luck. :mad2:
Edit: It might be a 12mm/28mm/8mm part. I am eyeballing with a ruler. MacMaster has this size part.
OUCH!
may I ask... what jackshaft?
the razor dune buggy for all I know doesn't have any jackshaft
(or are you talking z-2250L two seater?)
look at the second bearing and read it's number
all bearings are used in pairs of at least two..
chances are the other one is the exact same size and you can still read the number from it.
PS maybe an imperial size? R8 2RS for example is roughly 12.7x28.6x8mm in size
