Removing second output shaft
Gokarts4Life-11
The odd one
I have a tecumseh HM80 that came of a snow blower on my go kart. I'm currently working on putting a torque converter on this engine. The engine still has 2nd out put shaft that was used to turn the tires on the old snow blower. In order to mount the tc I would need to either grind/cut off the second output shaft or remove all of its internals...
What do you guys think the best solution would be?
http://www.google.ca/imgres?q=snowb...t:429,r:1,s:49&tx=104&ty=115&biw=1280&bih=709
wall gator
TAMPA BAY AREA
look's like some kinda gear reduction,to me. have you taken this off and seen what's there? post some pic's w/unit off, most have a splined pto goin to the driver....
Gokarts4Life-11
The odd one
I know its not a gear reduction unit, the pto shaft spins at 3600 rpm, if it only spun at 600 (reduction speed) my kart would only go 4mph. :wink2:
You can see the 2nd output shaft between the clutch and the jackshaft
r_chez_08
Should be in the shop...
Cornwall, UK
I am guessing that comes off the camshaft? If so if you did not like the idea of cutting it you could order a new side cover and cam.
kendelrk
redneck engineer
westland michigan
my tecumseh had a clutch brake box just with a hole drilled for it to fit through, dont worry about it, hook it up straight and leave it alone
