hey guys, well, i got my Tecumseh HS50 all tore down but, i need to remove the flywheel. The Problem is, i have no way of applying torque to the flywheel nut without the crank turning over. The motor is stripped down to just the block,crank, and flywheel. Any ideas? BTW the flywheel has plastic fins so a wrench in between the fins is pointless and i tried vise grips on the PTO shaft but it just slips. Thanks
