Remote throttle on Vanguard engine
Allracing
Hi guys
I have recently accuired a Vanguard 6.5HP engine for ‘’Wheelbarrow Hotrod’’ project. I borrowed this pic from the interwebs, I belive my engine is identical:
The build is getting near a test drive minus a couple of loose ends. One of which is the remote throttle. I have made a pedal assembly but have no clue how to go about it on the engine side. I do have the capability to make cables of various configurations.
So the question is, how do I connect a throttle cable to this engine? :)
karl
North east Ohio
Typically this is now it is done
Pull the cap off the lever, it should have a small hole for solid cable, and a bigger hole for a cable clamp insert like a predator/gx uses.
I would reccomend removing the gas tank and taking the friction washer out the the throttle lever pivot
Allracing
Thank you!! :thumbsup:
Much appreciated :cheers2:
Karl's photo shows a wire connected to the governor control [the lever] to operate the throttle. If you are going for a governor removal [for more speed, man!] the throttle cable connection is made at the carburetor and needs a return spring.
That wire cable actually looks like it's designed as a throttle control for a garden tiller and usually has a 'Z' bend at the end of the wire. Just so you know, that is not optimal for a powered vehicle. ;)
Allracing
This is getting interesting :)
Are there means of not overreving/ blowing up the engine if I go for gov removal? Reckless kids will be driving my kart ;)
Sent from my iPad using Tapatalk
Allracing
OK having lurked around the forum I realise this question is a biggie. I'll figure it out with the search function :sifone:
Haha, well the search function is cool and boy oh boy have we beat that subject to death...
However, since you mention reckless kids will be driving it it might be a good idea to retain the governor. It's not really a rev limiter, it's just designed to keep the engine at a desired speed regardless of load. But it's factory set to the industry standard of 3600 revs.
Anyhow, if you deleted the governor you could always fashion a throttle stop at the pedal or at the throttle butterfly on the carburetor for starters.
