Remote throttle on Vanguard engine
Allracing
Hi guys
I have recently accuired a Vanguard 6.5HP engine for ‘’Wheelbarrow Hotrod’’ project. I borrowed this pic from the interwebs, I belive my engine is identical:
The build is getting near a test drive minus a couple of loose ends. One of which is the remote throttle. I have made a pedal assembly but have no clue how to go about it on the engine side. I do have the capability to make cables of various configurations.
So the question is, how do I connect a throttle cable to this engine? :)
karl
North east Ohio
Typically this is now it is done
Pull the cap off the lever, it should have a small hole for solid cable, and a bigger hole for a cable clamp insert like a predator/gx uses.
I would reccomend removing the gas tank and taking the friction washer out the the throttle lever pivot
Allracing
Thank you!! :thumbsup:
Much appreciated :cheers2:
Staff Murderator
Karl's photo shows a wire connected to the governor control [the lever] to operate the throttle. If you are going for a governor removal [for more speed, man!] the throttle cable connection is made at the carburetor and needs a return spring.
That wire cable actually looks like it's designed as a throttle control for a garden tiller and usually has a 'Z' bend at the end of the wire. Just so you know, that is not optimal for a powered vehicle. ;)
Allracing
This is getting interesting :)
Are there means of not overreving/ blowing up the engine if I go for gov removal? Reckless kids will be driving my kart ;)
Sent from my iPad using Tapatalk
Allracing
OK having lurked around the forum I realise this question is a biggie. I'll figure it out with the search function :sifone:
Staff Murderator
Haha, well the search function is cool and boy oh boy have we beat that subject to death...
However, since you mention reckless kids will be driving it it might be a good idea to retain the governor. It's not really a rev limiter, it's just designed to keep the engine at a desired speed regardless of load. But it's factory set to the industry standard of 3600 revs.
Anyhow, if you deleted the governor you could always fashion a throttle stop at the pedal or at the throttle butterfly on the carburetor for starters.
