OK so i have a 36v 700w 2500 rpm electric motor and i dont want PHAT EXPENSIVE batteries on my modified wagon/go-kart, so i wired (4) 9v batteries in a series and (8) 9v batteries in parrallel for extra Ah when the 9v run out of charge. and the motor runs with the 4 9v battery pack.
my first question is: is there a way to attach the parrallel battery pack to the series battery pack so that i dont have to change them out when they are used up.
my second question is why has nobody ever done this? i realise that the batteries will be discharged quickly but they can be recharged (a method for recharging is still in the works, i was thinking charging with a low amp high voltage charger attached to all the batteries in series but that also seems problematic...
...also do you think the batteries may explode for any reason?
Thank all of you!
Thank all of you!
