Reduction box or centrifugal clutch
1111gsw
Hi guys i have bought a 9hp clone engine road rat 270 but I think the clutch is slipping as the oil boiling up and acceleration is poor my buddy has bought a different make of kart but has the same 9hp engine with centrifugal clutch he is 35 pound heavier than me but accelerates twice as fast is this the way to go or just replace the friction plates and oil in my reduction box thanks guys
1111gsw
Not sure until I get to the shop on Monday but that aside am I right in thinking that with the centrifugal clutch being a more direct drive the acceleration will be quicker ? My kart won't accelerate there's loads more lag than his and top end is more or less the same
A cent clutch is not any more direct drive than the reduction box. The only difference between the two clutches is that the one sits in oil. Iwill have to agree that it is more likely a gearing issue, and you are geared too high
1111gsw
My gearing is reduction box 2-1 I think then front sprocket 13t and 32t rear 11"tyre my buddy has 12t front 71t rear 11"tyre running from a centrifugal clutch
Yeah see, he's running 5.92:1 gearing; overall, you're running 4.92:1, he'll beat you every time until you either beef up your engine or change your gearing.
A 38t axle sprocket will give you 5.85:1
A 40t axle sprocket will give you 6.15:1
TKart
I guarantee you that the reason why the clutch is boiling over is because there is a small hole in the weight pack that is plugged with sludge. Take a close look at the small hole at about 5 oclock in the center of the weight pack. Take a small flat head screw driver and clean around the center bolt boss. Then take a small wire and poke it thru that really small hole in the pic. That small hole provides oil to the frictions. Replace the frictions/plates and clean the hole...prob solved. I service and rebuild these a few times a week...trust me.
