J.S.@SMS
Road Hazard
I have recently started rebuilding a gx200 clone engine and I would like to know which flywheel offset key to use. They come in 2, 4, 6, 8, 10 and 12 degrees offset.
Some of the things that I have done to the engine are:
Governor delete (all governor components gone and hole drilled to 1/4 and tapped for a 5/16-24 bolt)
New rings
New gaskets
New valve seals
New carb (Ruixing)
Cleaned up/slightly shaved the head
Honed the cylinder.
I'm planning on leaving valve train and crank assembly stock. I would like to get a key which would move the peak power into the 4500-5000 range. Would this work or is it just a waist of $7.50 +s&h.
New rings
New gaskets
New valve seals
New carb (Ruixing)
Honed the cylinder.
