The recoil starter on my 6.5 Hp Greyhound clone engine is busted and I need a new one. Anyone out there know a good source for where to buy a replacement recoil assembly.
Thanks
Con
Thanks everyone for the help, I ordered a recoil from http://www.ebay.com/itm/HONDA-GX160-...item1e63afa4ab as per Themurraykart.
The recoil starter on my Greyhound clone just came undone one day after the cord broke trying to start it, the spring part inside the housing unwound and part of the housing holding the spring in place was bent out of shape. I tried a few times to rewind the spring and install a new cord but it kept unwiding each time I pulled the cord.
Con
thanks for the website, im new here and have been scratching my head trying to figure out where to get honda parts, your the man thank you, i know this post is old but my thanks is new
Not sure if it matters here, but the cups and starters will not interchange between the blue jiang dong, and yellow bsp engines. They will bolt up, but the engagement teeth are different.
my cup and starter from my blue clone has interchanged with a yellow bsp, theres a black ring under the recoil starter from where it bolts up. use that ring on the bsp and it changes the engagment to where you need it, hence why a bsp will fit on a blue clone
