Rebuilding The Rotax 399cc
rushking19
Richmond Virginia
This is how it looks when life happens, i blew one of the pistons on the snowmobile engine so now it will be a while longer till I get it running again till I can buy new pistons, I kinda knew this would happen so I'm not too mad about it and it would be a good experience to rebuild a snowmobile motor :censored::2guns::mad:
n3480h
NW Iowa
Ow. Well, the good news is that you'll learn a new skill and the engine will be much better than it was. Hope you'll post updates on the rebuild.
firemanjim
Just kartin' around....
Houston Texas
One thing I noticed way before it blew it didn't want to start on that cylinder
That would have been the sign to not start it any more, and tear it apart before this happened. You might have been able to prevent this and the ultimate set back in time and $$$ . But, live and learn. I bet you don't do that again..... :thumbsup:
rushking19
Richmond Virginia
I did Tear the head off when I first got it even before I tried starting it and it looked Ok
rushking19
Richmond Virginia
Maybe it's the pic, maybe it's the computer I'm using (not mine) but, I can barely see the problem...
That was before here's a picture of now
Poboy kartman
Senior Moments Member
White Settlement Texas
Pistons and shock absorbers are two different things. .....
Basically. ....a piston is almost a non-moving part as far as wear in many respects. .....the rings take the brunt of the cylinder wear while the wrist pin takes the rod wear.......and the cylinders wear the most. ....so unless you are boring to another size.....the new and old pistons are going to have similar slop.......
Of course. ....if it doesn't cost much and you are paying for shipping anyway. .......
rushking19
Richmond Virginia
So it's OK to use the good old piston
Axx3d
MN
If everything is within tolerance you can reuse the old piston with new rings.
Axx3d
MN
Get a digital micrometer and make sure it is within spec. Id also verify both cylinders are within spec as well and not ovaled..
As said "looks ok" is not the same as within tolerance...
