rebuilding dfgka200, electrical questions
johndeerebones
Rebuilding engine, new jug, piston and rings. Anway while I'm there, Im fixing wiring, too. Speed sensor wires pulled out by battery by previous owner. Plug by battery side is two wire, red wire and blue wire, speed sensor is a three wire sensor. What wires connect to the two others for sensor. As far as I can tell, it is for the speedometer only. Furthermore, the wires immediately go inside the after the connection.
johndeerebones
Anyone have a wiring diagram? Also it's a 161QMK-B2, 169cc k block gy6, guessing ~10 years old I think. Also previous owner cut the wires to signals, both fronts have two wires, understand those. Rear has three wires, guessing tail and turns? What about brake lights?
Brake light has 2 circuits one for running light one for brake. It's triggered off the brake pressure switch on the master cylinder.
Good luck finding an exact diagram.
Find any china kart wiring diagram and use it for clues as to how yours is wired.
