spongerich
I'm working through some ideas for an off-road kart.
I've got a 12hp vertical shaft mower engine along with its Peerless 5 speed transaxle. I'm planning to use a friction clutch setup similar to what's on the mower now.
Since I'm old and don't really want to have my brains bounced around inside my head, I definitely want some sort of rear suspension. (I have the front covered.. I've got a frame and almost all of the suspension parts from a Honda TRX250x quad.
To keep things simple, I'm thinking of leaving the solid axles on the transaxle and mounting the engine and/or tranny on a subframe and springing it with either some coil over shocks from a quad or using some front forks from a motorcycle.
Would it be a bad idea to mount the engine to the main frame and put the transmission on a sprung sub-frame? I'm worried that the belt is going to jump off the pulleys if I allow more than couple of inches of travel.
I'm also giving some consideration to putting some universal joints on the ends of the rear axles and making a fully independent rear suspension, but I suspect that's going to be a lot more complicated and perhaps left for a future mod.
