Look close at this and you will see it is actually a bolt welded to frame.could i just use a long bolt and bolt the wheels on?
Hello everyone I dont know what to use for a fixed axle
or
could I use a long peace of threaded bar?
:rolleyes3:
Whether using a bolt or a bar, you only get the strength relative to the overall overhang. In other words, keep the wheel on the shaft as cloes as possible to the frame to reduce leverage from the wheel that will bend the shaft. If you do use a bolt or threaded shaft for the axle, make sure it is at least 3/4" or you use only the non threaded part of a 5/8" for the shaft.
Some people may not realize that the thread cuts at least an 1/8" into the OD of the screw.
Russ Barrow
Russell ATV
