Rear axle
Drmmr6622
i am building a off road go kart and i need some advice on my rear end. i have a setup to build a independent suspension. i just need some help finding u joints and other stuff so i can get this thing working. i put up a pic, if that will help u better understand my setup. i currently have a snowmobile engine in there so i need something to handle the power.
modelengineer
Lord of the noise
Sydney, Australia
How many cc's is it? If more than about 600 then I'd be going CV joints for reliability.
If not, people have had good luck with uni joints from land rovers...
Drmmr6622
its under 600
and where would i find the u joints at is there a place i can buy them new or just post something on craigslist.
motor_head
expert garbage picker
sutherland IA
pto shafts from old farm equipment would be cheep
1000 ones would be better than 540, if you want really heavy ones get a shaft for the big 1000 (the big 1000 is just a bigger version of the thousand) the picture are the male end, the pto shaft will have a female end the way to tell the difference is the splines
88s10Durango
Chilliwack BC Canada
Hi , I think your gonna be similar to my rear setup , lol , I just got all my shocks yesterday , I`m gonna be using some front forks on the rear also , I`m going to use a Jackshaft , have the ends turned down to 3/4" , then put one of these on each end with a high grade bolt through it and the jackshaft to keep it all together , will use a short 6" axle on the other end for the wheel hub , using pillow blocks on it , I will have to shorten the center section of these steering shafts for the right length , theres a U-Joint on both ends , the center sections are also a slip joint fit to extend or compress , the shafts are off a 1991 Jeep Cherokee , theres 2 different ones used in the Cherokee`s , Aluminum end ones and steel end ones , the steel end ones have a 3/4" hole in the yokes , the Aluminum end ones have a 5/8" hole in the yokes , these are about $ 135 average for one , but in the wrecking yards they can be had Cheap , here in my Pull It Yard I can get 2 of them for # 30.00 , its what I`m going to use , I do only have a 185cc Trike engine though , I still think they should hold up to your engine ,, Bill
theo
Those steering shafts won't hold up to that sled engine. I'm not sure if you are using a single a arm or dual. But for the engine you are using you need to go to a VW axle or a axle from a small car.
:ack2:
theo
theo
Also if you look you will see that this guy is using a comet diff. There was several guys using them with the sled engine.
theo
Drmmr6622
ok I'm looking at getting vw cv joints and axles but i need to know how i can make the 6 screw pattern into like a solid 1 in axle like in the kart above
theo
You can buy them, but you have to have deep pockets. To make them you need a weldable hub and then you have to make a disc with the same bolt pattern as the VW CV's.
theo
T-REVVV
http://www.americancvstore.com/servlet/StoreFront
this website has just what your looking for
newrider3
Colorado
Go to your local pick a part junkyard. My local sells complete CV axles for ~$20. Then you just have to have the ends machined to 1" keyed.
Daveon
Kent, Ohio
:ack2:
theo
Looks like it has a loose nut on the right A-arm
