Rear axle Manco 808-1
bosscat800
Wyoming
Was wondering about the rear axle on the manco, I believe its a 808-1. What do you lube the gears with, I have it apart and thought I should clean it and lube it. It kinda looks like it is just grease? Thanks for any help.
bosscat800
Wyoming
No, not the sprocket. Its the differential. Looked like grease but im not sure. Also, where is a good place to buy parts for these. Axle, or even roll bar parts?
Aaaah. The diff would need grease. There should be grease nipples for you to pack the grease in. If not, open it up and pack as much as you can in there.
Have you got a pick of the diff? That would help in the buying of parts.
